RCU Forums - View Single Post - DP Ultimate Ailerons - 4 or 2 servos?
Old 07-16-2003 | 05:28 PM
SkyDude's Avatar
SkyDude
Default DP Ultimate Ailerons - 4 or 2 servos?
Greetings,
On the DP Ultimate, I've heard there is an option to go with two servos for the ailerons, instead of four.
What are the pro's and con's of using just two?
From just guessing, having two ailerons would make mixing and servo setup a bit easier. It would also make field setup easier since you would not need to worry about running the upper wing servo wires down the cabane each time you attach the wings.
Cons would be the two servos would need more torque, as they are driving two aileron surfaces. And you would have a non-scale strut conncecting the top and bottom aileron on each side.
Am I missing something? What setup would you recommend?
Thanks!
