RE: Supra Fly 60 build
Chris,
very nicely done!
With the cowl and canopy molds, you should consider making a short kit including these, and laser cut wood for the fuse and cores for the wings, stabs and turtle deck. Glass, carbon decks sound nice but they do require painting. Using sheeted foam decks gives you the option to produce a model which can be entirely covered (except for the cowl).
BTW, what industrial mold material did you use for the cowl? Where to obtain it? I like what appears to be a relatively easy pour into the mould container approach.
David.
P.S. I'm building a Calypso at the moment - getting retract gear work done on the panels.
