RE: CA Models VISA
Chip -
Do you have any pictures of how you have your speed controller mounted in the fuse? Also, tell me about any ducting that you feel is necessary for cooling the motor. I saw one pic where it looks like you have ducting over the top of the motor.....anything to deflect the air from the front intakes upward over the motor? I am also assuming that the air ducts in the rear of the fuse are all the exit holes that are needed and no additional ones should be cut out, correct?
Thanks. Plane is moving along great. I am very pleased with the quality!
