RE: GWS Beaver
I suspect that the very light weight GWS prop blades is flexing and moving relative to the prop hub thus reducing the propellers efficiency, down to where a similar amount of thrust is produced by the 8x6 GWS propto the 7x5 Master Airscrew prop. You never stop learning in this hobby do you. I knew that different brands of props were different but not to this degree.
