ORIGINAL: alexdrift i have changed the transmitter from mode 1 to mode 3, but the rudder and aileron trims are mixed up, can anyone help with this issue
Mode 3 (reversed mode 2) = Left stick: Aileron and Elevator (cyclic) - Right stick: Throttle (Collective )and Rudder
What physical changes did you make?
With TXin Mode 1, simply swapping the Rudder and Aileron servos leads on the RX will give above results.
Youmay progress using a little lateral thinking with P-mixes as Eclipse has no provision electronically for other than modes 1 & 2,
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
