RCU Forums - View Single Post - FUNJET
Thread: FUNJET
Old 04-09-2010 | 07:38 AM
  #1049
chippedprop
Default RE: FUNJET
ORIGINAL: blkz2801
Ok, I am really frustrated now. I am having a really hard time screwing the motor into the mount in the back of the plane. Anyone have any ideas? Also the bottom screw seems like it doesnt go into any materal to hold it down. I think i stripped the flathead screws Help!
You can go to the LHS and look for small long bolts to go thru the holes you may have to drill out with a 1/16" bit. I think the bolt size is 4-40 or 2-56 hex head or phillips will work...
Measure the length you need...I would use nylon insert nuts to keep them tight (self locking) Get washers also...... fender washer if they stock them....fender washers are larger dia. but not the hole size.
I use this to attach my mounts to the flat deck...works every time.
Mount adjustment will be the same as on a stock mount...your just going thru the holes...questions???
Cp
