RE: Top Flite 1/7 P-51 Arf retract problem
how would you use a separate battery for the retracts? I've got a 2300 or 1700mah 6.0v now... I forget which for sure, probably should check before I fly it this year. I'm leaning towards the 2300 though, due to all the servos!
I went out tonight after work and moved the quick links in to the center holes of the JR arm, no clicking or binding. I've got it on charge now, will check it out again in the AM.
Thanks for your help guys
