ORIGINAL: w8ye
I bought a engine from Todd this morning. I was there 1 min after they opened. I have it here beside me.
You will love the engine.
BTW - I noticed on your profile you had a starter bench with some short uprights that would not work well for high wing airplanes and another bench that may tip forward with the power from some of the larger gas engines if the benches are made from untreated lumber or if the flight box is not mounted properly. I also did not like my transmitter balanced on a 2x4.
Here is a different design that will not tip forward as easily and it has plenty of room to put a flight box, transmitter, etc. on the top. It is also very easy to build, even at the field. They can be made from treated or untreated lumber. The second picture has the old bench in the background, notice the concrete block at the tail of the bench to prevent the tipping problem, and Walt with his "gasser" running up on the new bench.
