RE: NEW DLE30!
trpastor,
If your going to use the original throttle arm instead of the longer one supplied you can remove the screw and flip it over if memory serves me correct and it gives you the correct orintation. The screw is really tight and you'll probably have to heat it up as I did to get it to come loose.
