RE: Differerential
TruBlu02, yes, they taught usthat in pilot flight school back in 1976,and being an old timer, my memory is slipping a bit in the evenings after a couple of Taliskers....but, yes, you are right,there are more factorsinvolved thansimply transverse wing turning dynamics -true airspeed over both wings in a turnaffecting lift and drag on each side (but Falcon is concerned aboutROLLING in a straight line, not banking).
One also needs to checkaileron movement for binding limiting movement to one side, down/side thrust lines,lateral (cg) wing balance,positive/negative horizontal stab angle (bad build quality), skew fin, possibly warped wings, warped ailerons, unequal (unsyncronized)aileron servo movement, sloppy/loose hinges/control rods, improper programming ofTx, esp with electronictrims, zero and movement.Sometimes it could justbe a loose servo.....
Falcon 32 did not say which plane is doing it. Ifthe plane's set up is 100% good, high wing planes (Cubs etc) are more difficult to roll than low wingers, they have a natural tendency to roll out (corkscrew) .
If heis flying mode 1 or mode 2 - some right hand/left hand people find it easier with one or the other when it comes to aerobatics. Switching modes can also effect flying,On mode 2 the the elevator and aileron gimbal springs settings also have an effect. I prefer my mode 2 Tx gimbal spring to be slightly stiffer on the elevator than the aileron and on mode 1 the elevator gimbal spring stiffer than the rudder one,but that is personal preference.
But one need to try the very basics first, then go int the above checklist
Cheers mate. Bundubasher</p>
