now if it still wont start turn the truck over with out the plug in it and pull it over kinda fast till no more gas mix comes out. then take either starting fluid or brake cleaner and clean off the plug and then turn you needles in all the way and then try to start it. if it starts make sure you have the truck off the ground bc it will run and it will rev up fast so be ready to shut the engine down with you killl switch then start it again and make sure it dont over rev. and continue that till it wont start anymore then turn your needles out about 1 turn on low and and about 1 1/2 on high and you shouldnt need to choke it but if it dont fire at all go at full throttle and try to start it. hope that helps man. also check out my thread
http://www.rcuniverse.com/forum/m_96...tm.htm#9647286 i had the same problem the other day and it flooded and it had the darnest time to get it started. that is what i did ( above ) and it worked for me. hope all this helps you out.
TJ
