RE: Engine Tuning Help
Yes, the low end reflects a lean or rich mixture. Take a tach, and run the engine to full throttle per the rpm recommended. then back the high end down around 200 to 300 RPM. If the transition is smooth then point the engine up. If it dies, the low end is to lean, if it dies pointing down, it's to rich.
