RE: Large 1/5 scale SM F-86 CG ?
BTW, how did you guys attach your stabs to the fuselage? You can either glue them or attach with the 2mm screw thru the carbon rod on the stab. When I use a 2mm screw I have a gap between the fuse and stab and it also wiggles up and down. On the other hand if you glue it in place then you cannot remove the rudder for service. Not a fan of the design at this point, too many problems in this area of the plane...
