RE: Evolution 26cc GX Gasser Battery Help
You will have to find out how much current the ignition module draws and then take pe reivers suggestion to get the right Sanyo pack for some decent flight times. I know that the CH ignitions draw about 300ma so a 1500mah battery pack will give you about four to five hours of run time. The CH ignition comes with Futaba connectors and you can order the battery pack from Cermark with Futaba connectors. Dan.
