RE: Don Anderson GP Super Aeromaster build from plans
stevenmax50
Great news about the arrival of the kit. Mt plans are to power my plane with an O.S. .90 that I have, it's an older engine but it pulls great.
I'm also considering a possible swap to a SAITO 1.00 if i can get a good deal on one. If you want 3-D performance go with a Y.S. 1.10 or
something similar and use the short wingspan option.
Here is the latest bunch of photos for the build, these are the I struts I'm using for this build, they are hard balsa ply and balsa. there will be
pins made to hold these in place as i'm not going to use any screws for this application. I made the pins from two sizes os brass tube and
soldered washers to the smaller diameter tube which will be drilled to accept the clips made from piano wire. The larger diameter tube is used
as the sleeve in the other part for the wing mount.
