RCU Forums - View Single Post - New to scratch building!
Old 04-12-2010 | 08:37 AM
davidgeorge212's Avatar
davidgeorge212
Default RE: New to scratch building!
I think you could definately try that. The only reason you use the kicker is so it will immediatley cure. If you dont use it you just half to hold the balsa wood in its shape until the glue dries which might take a little longer. You can check it every now and then by releasing a little pressure and if it starts poping back up, keep holding it.
