RCU Forums - View Single Post - New to scratch building!
Old 04-12-2010 | 03:34 PM
Gray Beard
My Feedback: (-1)
Default RE: New to scratch building!
ORIGINAL: mike31
You can always lay the fuse up with balsa strips about 1/2'' wide. Sand to suit.
This is true, I have a couple of those way cool strip cutters and you can angle the cuts so the sheets line up without the flat gap. Strip sheeting is something I do on very tight curves. With the cutter angled you use almost no filler.
