RCU Forums - View Single Post - DLE30!
Thread: DLE30!
Old 04-12-2010 | 08:09 PM
  #2315
jedijody's Avatar
jedijody
Default RE: NEW DLE30!
I think you may have the description of your choke backwards, it should die when you close it. Did you rotate the black plastic insulator with your carb, if so, that is likely the problem. The insulator and it's gasket must remain in the OEM position or it will not be able to pump fuel.
