RE: DL-50 engine
Use a different type of gas filter in the can and somewhere before the carb. If anything is getting into the carb it's telling you the filter does not handle the smaller particles well enough. You should be using a filter that will stop particulates down to a minimum of 10 microns. If your filter has a screen, it can't do that.
