RCU Forums - View Single Post - Official F27 Stryker Part 8: Beginners to Custom Darkness
Old 04-14-2010 | 12:05 AM
  #1245
The1User
Default RE: Official F27 Stryker Part 8: Beginners to Custom Darkness
Gryphon: I did get the Heatsink you recommend, THANKS !!
Some examples of how others here run the MEGA 16/25/2 is probably the best way to help my small brain figure out what to do
So I have an ICE 100 and a 16/25/2
I will buy whatever battery or batteries (single, serial. or parallel) that will
give me the most speed at as close to stock flight times as possible (WITHIN REASON)
Gryphon : 4S-5000 and prop accordingly
What props would you recommend ? and what kind of speeds and flight times?
moparmyway : 8x6 or APC E 8x4 on 3s 5000 "80-90 mph speeds in EVERY direction"
What kind of flight times?
BubbleGum : 7x5E on a 3 cell 30C 2000mAh to 5000 "Speed is good but not much over 100mph"
If I go with the 30c 5000 what kind of flight times?
and how is the Vertical performance ?
Any others have a Favorite setup ???
Thanks everyone, will post build pics and flight video as it happens
NOTE: I have an Idea on reinforcing the Stryker instead of using round rods why don't you guys use the flat bars?
They are VERY strong in one direction, I saw a build video on a company website that sells EPP wings where they just
razor the the bottom push in the flat bars and glue them in (very fast and easy)
So they end up Very Strong left and right across the wings but not front to back, Comments?
Thanks Again
Joe
