RCU Forums - View Single Post - Strange Knife Edge Behavior
Old 04-14-2010 | 07:30 AM
Jetdesign's Avatar
Jetdesign
My Feedback: (8)
Default RE: Strange Knife Edge Behavior
Sierra, is your rudder servo mounted in the tail or inside the fuse? If it is inside the fuse, I would wonder if it is the control rod flexing under load.
I had the Venus II with the same engine; the plane should be able to hold knife edge all day and all night. I had the JR DS821 for all servos on a 6 volt power system - that's 88 oz-in of torque. It was enough to fly the plane though I'm not sure what would happen with less power on the rudder. The Futaba S3010 is the standard, hi-torque, ball bearing servo and has 72/90 oz-in depending on battery.
What are you using for a prop?
