RE: Gonna build a KIT!
As a kid I built a lot of stick and tissue planes. As an adult I recently started building again, my second kit was a TOP FLIGHT GOLD EDITION (AT-6). This kit has just fallen in place. There are tabs on the wing ribs that keep everything straight, and for the first time I’ve built an absolutely absolutely straight wing. Manual is extremely clear and easy to follow, and all the die-cut pieces simply fell out with no bad edges/broken peices. Engine offset is designed into the plans, it's probably harder to screw the plane up than it is to build it.
I’ve never seen such a good kit. I’m so impressed that when finished I’ll probably send top flight an email (and ask for some larger sized kits).
