ORIGINAL: yl5295
NEW FEATURE
Guys... I have a new feature available by special request now. It is a special mode for the Cessna 337. Since this is a push pull rather than a traditional (left - right) twin I have come up with a special mode for this airplane on the TwinSync. Here is how it works:
Never idles an engine even if one quits (similar to mode 6 but enabled all of the time).
Does not sync engines above 90% throttle (just gives engines full power)
The reason that it doesn't sync the engines at full power is because of the push pull arrangement one engine will always be capable of turning more RPM than the other. Therefore sync'ing them at full power robs you of peak thrust. To make them sync just pull the stick back a couple of clicks and they fall into sync.
All other modes are still there (independant run up mode, aux ch defeat, etc). The above two features are turned on all of the time in all modes. So only ask for this version if you have a push-pull setup. This mode is only available direct from me by sending in your IC (or board) and requesting it.
I would like this programming. I am building a 337.
Where do I send the unit to be programmed?
Address Please
