RCU Forums - View Single Post - Yellow A-4 DF, Is this normal-
Old 07-18-2003 | 01:08 AM
Jetman007
Default A-4
Had 2 of these. Flew them out of a 200' paved runway.
Things to look for:
- cheater hole, 6 sq in minimum, base of inlet ducts, uses nose gear opening for aux air.
- Nice smooth inlet at the outside of the fuse. No ridges!
- Inlets not collapsing when at full power
- Exhaust tube and duct work fits well with no leaks
- Engine is truly turning 23k+
- Fan rotor not slipping
- 10% Ducted Fan fuel (not sport fuel)
- Hard tires not spongy soft
- No drag on the wheels - spin freely, well greased
- Model weighs 10 - 11 pounds dry or less
- Fan rotor has minimal clearance to shroud and clearance is same all around
- Engine piston sleeve is properly oriented not rotated so timing is screwed up
- No fuel restrictions (like kinked line, dirty needle valve. . .) - need all the RPM you can get
Bout all I can think of now. Let us know what you find
