ORIGINAL: RCISFUN
ORIGINAL: topgun24
I have assembled and flown both planes. Both are excellent!!!
The flash landing gear uses pins to hold the struts into the landing gear which can break on not so perfect landings or if you grind too big of a flat spot when installing.
No problems if you use trailing link gear
I have the Dreamworks trailing link struts on both the Bandit and the Flash.. Work great.
