ORIGINAL: typicalmale78
Order # yhst-17210252890263-121194
http://www.nitroplanes.com/gl603-8-a...srtf-blue.html
Hello,
I just ordered the product in the above link and during assembly I have found a problem. I had the battery charging while I was assembling the aircraft and before I installed the wing I decided to connect the charged battery and check out all the servos and motors and such before finishing completely. My problem is that one of the ESC's seems to be damaged / broken. When I connect the battery it sounds like one of the ESC's has a constant beeping tone and the motor attached to that ESC ''twitches.'' When I disconnect the motor from the ESC and connect the motor to the other ESC the motor works fine and there is no beeping noise or twitching. Also when applying throttle with the controller the motor attached to that ESC never rotates. I have checked the wiring and I can't seem to find anything out of place considering both ESC's jump off of the same main wires from the Rx. I would really appreciate any help and or info on replacing the damaged ESC considering it seems to be glued in place and the wires are soldered. Thanks in advance, Jeremy.
ok before I do that. Please turn on the radio, put the left joystick up and then connect the battery to the ESC. Does both ESC go into the programming mode?
Also Please check the Y receiver harness cable and make sure the plug is properly connected to the correct color wiring.
John
Nitro Planes
