FwIW,
After seeing the gear from composite arf, I was not much impressed. Two of my bud's here bought a set and it took parts from each set, to get one set to work. One valve didn't work, the nose strut for the other would not fit in the retract unit.
The wheel bushings had to be drilled out because the axles were to large, and the brakes would barely put any friction on the wheels.
And Steve, if you think you viper is faster than my Hunka Junk Starfire, You must be on crack!
Joey
