ORIGINAL: goirish
ORIGINAL: opjose
I saw an article for beginners today that recommended this battery pack formula as a STARTING point...
Battery Pack capacity needed on plane = 1000mAh + ( 250mA * Number of Servos used in Plane ).
That is more realistic.
that makes lots of sense to me. Had not seen that formula before. I normally use 2500mAh in both tx and rx. The only 4.8v I use is for the ignition on my gasser. It is also a 2500mAh
i used to use 4.8 on my ignitions, not anymore....i now use a 6 volt 2500 mah AA pack with a cheap inline 6.0 v reg on the output of the switch... with a 4.8 pack, if you lose a cell, your motor will die
