RCU Forums - View Single Post - Dynam Hawk Sky weird power changes
Old 04-15-2010 | 07:30 AM
foambreaker
Default Dynam Hawk Sky weird power changes
Hi. I just finished building a Hawk Sky and when I pullback the right stick (elevator nose up) I get a decrease in throttle(unexpected) as well asnose up elevator (expected). Nose down elevator on the right stick doesnot seem to affect the throttle setting. If I put in nose up elevator on the right stick then return it to neutral center positionthe thottle goes back to the proper setting when the right stick is centered. I have checked the connections to the receiver and they seem to be right. The left stick does work the throttle as it should. Its just that the right stick will decrease it when it is set to up elevator and put it back to normal when the right stick goes back to center or in down elevator position. Any ideas? The plane came as an RTF so I only had to connect the ailerons to the receiver.The plane came with all the other wires already attached to the receiver. Weird isn't it?
