RE: B-ARF or Flash
My stock Flash landing gear came with 6mm pins not the 8mm dubd mentions in post #20. I heard of some modifying the 6mm to 8mm but I have not done so. Since the Flash landing gear is bolted into wood and NOT flex plates like the Bandit I was advised not to go with 8mm pins as they want the pins to break before the wood in the wing breaks. Not sure if he drilled out for 8mm pins or if they upgraded the stock gear.
