RE: Found an SSR 1/2A
Here is a pic of the plans - there is quite a range for the CG. You should be able to get a pretty good idea by figuring the CG as a percentage of chord and applying to your fullsize wing.
Based on a 7" chord, the CG falls between 1 7/8" to 2 3/4" from the LE.
andrew
