I bought an mini ASK 21 from Nesail and it came with really bad instructions. I am at a loss as to how the elevator is suppost to connect to the wire that pushes up through the fuselage. There is only about a half inch between where the wire comes out of the vertical stabilizer and where the elevator sits in neutral position. So I put a whole in the elevator and ran the wire through, but now there is no way to make it connect. I was just going to glue the wire, to the elevator, but was wondering if there is a better way. Not sure I trust just gluing it.
