I did a small test flight outside and all it wanted to do was fly backwards, no forward momemtum at all, even with the right stick pushed full forward.
Oh well...
ORIGINAL: Eddie48
Yes, okay I'll remove the arm from the servo and reposition them.
I can use an Tenergy 25C 900mAh 7.4V 2 cell battery with the Madhawk 300, it's the same battery I used for my Blade CX2, I'd just have to tape it into the holder because it's a narrow battery. I accidently damaged the red and black wires on my 7.4V 2 cell 1000mAh battery because I was trying to gently put it into the holder. Smoke started to come from the battery wires, so I don't know if it is good or not. See photos below...
Other than that everything works on the Madhawk 300, the main blades and tail rotor blades all spin with the 900 mAh battery attached. I put a heat sink on the 370 main motor to help keep it cool.
ORIGINAL: yadac123
ok after it got initialized are you able to control the servos? if yes, that means you need to remove the arm from the servo and reposition them. Make sure when you do that the trim on the right joystick are centered.
Andy
