ORIGINAL: SV27dayton
SRT said:
when properly setup, this boat should see 40's with that KV on 3s, but it sounds like it is going much slower than that and to me it indicates that there is something wrong with the setup...
OK. I agree. Honestly It doesn't sound like you are tuning the revs you should with that motor. Are you shure it's 3600kv? To clarify I have a charger like what SRT is speaking of. If you were to have to stop mid run when you charge you would see that you only put back 2300 mah. It steadily increase as the packs charge like you are filling a bucket. Nice indicator for when your packs are cooked.
Yep right on man, that's what I ment..
this motor should be at 40,000rpm unloaded and it sounds like its only 1/2
