RCU Forums - View Single Post - low throttle setting - will it hurt the engine?
Old 04-17-2010 | 04:15 PM
sandal
Default RE: low throttle setting - will it hurt the engine?
Thank you for the info, that is really good news! I'm using a Menz S 18x6 prop. The low end is set fairly lean, so there is no midrange gurgle (only at high idle). There is no hesitation when I hit the throttle. I must say that this engine runs incredibly smooth, considering that it has only run a few hours.
