RE: installing the engines on new brushless A-10
It does not mater how you hook them up. Just make sute that the fan is going the right way and if is no pushing the air then just chage one wire around on the motor and it will make it go the right way. So just plug them in any way you want and run it up and see it the motor are going the right way and then you are good to go!!! You can hook them just by the color and then see witch way the motors are going and like I said if one is going the wrong way just change one wire and bada bing.
