ORIGINAL: ES CONTROL
When I first take off , I trim my elevator at full throttle to 3/4 throttle. And that is were I leave it. Is this correct ?
Or should I learn to adjust as fuel level goes down. and again for landing.
<br type=''_moz'' />
I guess my only question is, does the way you trim work for the plane and the way you fly? If it does, and you enjoy flying the way you set up trims, then there really isn't a reason to change the way that works for you. Keep it simple.
As for myself, once I have the trim set up for the way I fly that plane, it's there and I don't change it.
