RE: 170 cdi Help
chad
check ur plug gap .35mm-.45mm also run a 19x 11 apc. I would set the plug gap at the .35 in some cases the gap does open up a bit and cause the motor to run rough in transition
in more extreme cases they act like its running lean and even spit the prop misfiring very badly . A carboned up plug will also act like this.
gary
