RCU Forums - View Single Post - The E-flite Blade SR Tips and Tricks
Old 04-18-2010 | 10:41 PM
c9403
Default RE: The E-flite Blade SR Tips and Tricks
From my "yellow wire" and tail motor thread, I learned this:
<div id="TixyyLink" style="BORDER-BOTTOM: medium none; TEXT-ALIGN: left; BORDER-LEFT: medium none; BACKGROUND-COLOR: transparent; COLOR: #000000; OVERFLOW: hidden; BORDER-TOP: medium none; BORDER-RIGHT: medium none; TEXT-DECORATION: none">Fixed.  Got my tool kit out and soldered in a new tail motor and put on a new tail boom.
After about 1/2 a battery pack, I had the gyro and the proportional adjusted back to where they belong.  A few trim adjustments and she was good to go.  I was hovering in my kitchen, a huge accomplishment for me to fly a larger heli in a small space.
So here are my observations as I examined my old tail motor.
When the heli was brand new, the tail motor would make that buzzing / grinding noise that everyone complains about.  Once it quit holding the nose, it no longer made that sound.  The new motor is very quiet and has a manufacture date about one month after the original one put in by the factory.
When the heli was new, the tail rotor would begin spinning up as soon as the main blades began to spin or shortly after.  As it went out, it would not start up until much later and was weak in power.
The heat sink is easy to reuse for the tail motor.  It is not glued on and simply pops off and goes on the new tail motor.
So, here are my theories for why the motor went out after about 20 flights:
1.  Bad motor, stuff happens.
2.  Crash damage??? Maybe the tail struck something and caused a slight bend in the motor shaft that wore out the motor.
3.  While trying to plug in the infamous yellow wire, I plugged it into the wrong port and/or wrong polarity and fried the motor.
So, I hope someone else can learn from my mistake.  I  believe that you can adjust the gyro gain remotely with the stock transmitter, but for me, the pot on the gyro will do fine.  Still searching for that perfect setting where the twitch almost disappears, but you have good control.  Not sure it exists with a non-belt driven tail, but I will try to get closer.
For anyone else who wants to try, I would suggest that someone put it in plain english as to how to do it.  In other words, take the yellow wire, plug it into the 5th pin from the left and make sure the yellow wire is on the bottom.  Then, in using the Channel 5 knob, you get xxxxx.
Read more: <font color="#00265e">http://www.rcuniverse.com/forum/m_9659557/anchors_9671414/mpage_2/key_/anchor/tm.htm#9671414#ixzz0lVuxODsK</font>
</div>
