What version ECU do you have? Second you could program a throttle curve in your radio. Then again you could be having an internal fuel leak. Take the casing off and look between the fuel connector and lube connector while pumping fuel into the fuel line. If there is no leak press 1-2 then 3 and back to 2 then go to # 23 and reduce than # or call Carlos or Bob price
