RCU Forums - View Single Post - RAM500, different pump, help.
Old 04-19-2010 | 10:09 AM
Ravivos's Avatar
Ravivos
Default RE: RAM500, different pump, help.
ORIGINAL: basimpsn
ORIGINAL: RCISFUN
ORIGINAL: basimpsn
What version ECU do you have? Second you could program a throttle curve in your radio. Then again you could be having an internal fuel leak. Take the casing off and look between the fuel connector and lube connector while pumping fuel into the fuel line. If there is no leak press 1-2 then 3 and back to 2 then go to # 23 and reduce than # or call Carlos or Bob price
OMG .... you published the secret code[X(][X(]
Woops should be PM
Hi basimpsn,
i have the CO3 version.
i manage to hack my way into the CO3 factory settings and changed the relevant parameter (110) and now the turbine works perfectly.
thanks.
Ravivos.
Soo you are good then??. (110) [X(] I forgot the 500 setting different from the 750
As for now ...
thanks
