Here are some shots... got a good bit done over the blustery weekend. First an over all... I put a yard stick under the wing.
Next a close up
And lastly a kinda top shot.
Inside the front canard controls are on a sliding tray. The tray is hooked to the gear servo right now so I can alter the AOA of the front canard by 3-5 degrees. Its in the full up position in these shots.
The CG is about 1.5 inches back from the leading edge at the root, but I think it might need to move back. Weight is still under 30 ounces with everything in it which is my goal.
KKKKFL
