RE: JetJoe OWNERS thread
Hey Jack,
On the ECU you should have a prime option, disconnect the fuel line to the turbine and hit the prime option to make sure you are pumping fuel from your pump. After a pump has been sitting for quite some time the lines will gum and clog a bit. If you are getting fuel and the degausse magnet tric does not work your fuel ring in the cumbustion chamber might warrant a look to make sure it is not clogged.
Joe
