RE: CMP 120 Zero ARF Build thread
You guys have done some great things with these ARFs! All the weathering and additional scale details are great! I also appreciate the info on the landing gear reinforcement. This is an all-too-common tale with ARFs and I add as much as I can without opening up the wings. I have the CMP Zero 50 and never thought about panel lines or weathering...until tonight. I also just traded a fully functioning BH Models T-28 - less the receiver and battery - for a CMP Zero 120. I've got a brand new SV 26cc gasser just itching to pull this bird into the wild blue. Just one small detail is missing - the "manual." I can probably put it all together without the manual but where is the recommended CG? I had to practically strap a brick to the firewall of the little 50 size to balance the thing at the proper CG, so will I need to bolt on a cinder block to this bird?
Keep up the great work!
