Servos are bad?
Is there anyway to test if your servos have gone bad in the way of being stripped? Mine servos turn the elevator but if you make a quick movement by holding the servo arm and push one way or another you can here it sound as if it is sliding over teeth. Does this suppose to happen?</p>
