RCU Forums - View Single Post - Engine cooling with cowl aircraft
Old 04-21-2010 | 08:21 AM
wjcalhoun
Default RE: Engine cooling with cowl aircraft
Gentlemen
THanks again
As noted, I'll check and clean the fuel filter and clunk, richen up a little, and install a port side baffle. If that does not solve the problem, I'll consider opening up the cowl a bit more over the cylinder head if those things don't completely solve the problem. One last question - do you generally use an infrared temperature gauge to assess cylinder head temps on your birds?
