RCU Forums - View Single Post - Engine cooling with cowl aircraft
Old 04-21-2010 | 01:10 PM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default RE: Engine cooling with cowl aircraft
I use an air dam on my gasoline powered planes. Gassers run a lot hotter, so cooling is CRITICAL if you want your engine to survive more than a few gallons. It works. Check out this cowl on my 75cc Extra. The lip goes around 3 sides. I didn't make it - came from the factory like this. But it's not just for looks. It's a functional air dam to draw air out of the cowl. The louvers on the side are cut and functional as well.
ID:	1422130   Click image for larger version
ID:	1422131   Click image for larger version
ID:	1422132   Click image for larger version
