RCU Forums - View Single Post - Diagnosing the problem with my evolution 40
Old 04-21-2010 | 02:27 PM
Campgems
Default RE: Diagnosing the problem with my evolution 40
Did you blow out the spray bar? It kind of sounds like you have the balance between the high speed and idle mix out of whack. Tighten the high speed and back it out two turns, set it to idle and tighten the idle mix and then back it out two turns.Then see how it goes. It sure sounds like crud in the spray bar though.
Don
