RCU Forums - View Single Post - Any experience with Hitec's Supreme IIS 8 Channel FM Receiver?
Old 04-21-2010 | 04:50 PM
armody's Avatar
armody
My Feedback: (10)
Default RE: Any experience with Hitec's Supreme IIS 8 Channel FM Receiver?
John.,
Sorry that answer litterally slipped outta my mind. Throttle servo had nylon arm, and the push rod was bent to go through the servo arm hole and there was another nylon piece attached to it to provide support by not letting push rod pop outta servo arm. The push rod connected to Car it was Z band and metal to metal, I did not use any clevis I guess I used the right word or any kind of plastic connector to connect the throttle push rod to carb arm. So push rod had a Z band and connected directly to the carb arm.
I hope I have explained it well. Does it have to do anything with something that happened?
Mody
