RCU Forums - View Single Post - Switch and charge
Old 04-21-2010 | 05:49 PM
CGRetired's Avatar
CGRetired
Default RE: Switch and charge
It is much safer to charge the battery outside the plane. And as far as a switch is concerned, well, there are not many small switches that will handle the current flow you are talking about here. It is not a good idea. Just go with the standard and remove the battery after flying and recharge it that way.
If you want more than one flight, then get a second or a third battery pack.
CGr.
